clutch is dumb
Spiker
Car: 1990 240sx Hatchback
Ok I on my 240 one day my clutch was too the floor just stuck! So I go buy master cyl and slave cyl replace it and bleed the line and bench bleed the master one time. Now my pedal has choke pressure. I go to drive bite point is at the top of the pedal. I hop under there and adjust it and fkn no matter wheere I adjust it too its at the top of the pedal. Its like there is no pressure above the biting point period. Is my clutch going too and I'm just having multiple problems at once or am I doing something wrong with the bleeding and adjusting. I need to move my car from my old house cuz I got evicted and this is driving me insane. Thanks for the help.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
It kinda sounds like your clutch is giving out. I would still check the clutch fork and slave alignment but it seems like if that were the case you wouldent be able to disengague the clutch. It sounds like there is no clutch material left and the pressure plate is barely holding it onto the flywheel. As soon as you touch the pedal it disengauges. It's also possible the clutch fork is either not seated properly on the pivot pin or that it's not correctly seated on the throwout bearing but that should make the fork sit on a funny angle.
