Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Sat Mar 22, 2008 5:12 pm
Whiteg35Bullet:
did your friend use the clutch alignment tool/spindle to ensure the clutch was aligned with the flywheel? If your friend didn't do so, or if he did it wrongly, then the clutch was not aligned with the flywheel properly, and thus Beancooker is right about alignment. The alignment tool is usually a plastic material that has some teeth and aligned with the teeth of the hole in the middle of the clutch. That tool looks insignifacnt but yet very important in ensuring that the clutch is properly aligned with the flywheel.
