clutch interlock relay
sleepersilvia92
Car: 1993 240sx coupe s1 rb25det,1989 hatch sr20det
i have a 1996 240sx i put my motor i had from a 95 in i had it idling but it was rough and i was trying to do the timing but when the timing light was on i tried starting in and i blew a relay because when i tried it it kept on clicking i narrowed it down to being the clutch interlock because i swapped one next to it and it started but then the relay went out again a few tries later and im stumped i need the car to drive and im getting fed up i tried posting in a old thread about the interlock relay but had no luck can somone please help me. can i just jumper it and not even have to worry about it im confused and tired can somone help me out????
sleepersilvia92
also what relays are inside the car ?????? i am so mad
verSat1l3
Car: 93 S13 Fastback 96 S14 SE
you wont get an answer to your problem because its so freaking hard to make sense of the description of what you are trying to do and whats going on when the person reading does not know where one sentence starts and another one ends in the future try to use punctuation and better explain the issue in clear concise statements so that we may make sense of the issue instead of getting a damn headache from what you posted on the inside of the fuse cover there should be a diagram of what relays are in the fuse panel and surrounding locations if the relay is clicking then its bad if the starter is clicking then you drained the battery down in the bottom of my sig is the factory service manual for your car i suggest you consult with that in the electrical section i can find no mention of a clutch relay just a clutch switch and the automatic speed control device switch which means the cruise control clutch switch the relays are for your ignition i hope you gave up reading this by now because your post gave me a headache and i think ive made my point
zachattack_5491
Car: Pignose S13 Redtop SR
There is certainly a way to bypass the clutch interlock. I don't know how personally but I'm just trying to give you some hope... search as hard as you can and you'll find it. I don't have clutch interlock in my car, just don't forget to start in neutral lol
sleepersilvia92
The relay i keep on blowing is the clutch ascd cut in the fuse box under the hood. I replaced it with the one next to it and it blew out that one too. When i turn the key the 4 relays in the car click also and it has power just doesn't crank. It started right up the first time, but then the relay went out. Does anyone know what could be causing this? I looked at the wires that go to the relay in the fsm and connected them but that didn't help. It did the same thing. If the key is on and i push the clutch in until the switch goes in and you can here the relay clicking on and off. I think it went out when the timing light was hooked up because it wouldn't start after it was hooked up. Can anyone help me? the car is a 1996 240sx. thanks alot
