Clutch interchangibility, searched.
GriffinW
Car: 1991 S13 KA-T
Will an SR clutch work on the KA's transmission? Tons of awesome clutches for the SR but the KA is lacking.
TheOne
Car: 93 240sx FB
i believe spec sells a flywheel that you can mate sr clutches to on a ka, but direct bolt on, no.
GriffinW
Car: 1991 S13 KA-T
thanks.
S13FX
Car: '69 l20b Dimeski :)
UHM there is a **** load of clutches for the KA.
For instance SPEC. I love their Stage 3+ clutch and steel flywheel
sstomek
drape123
Car: J30 94, REAL CAI W/POPCHARGER, ECU-Reflash. (the DD) - 95 S14 KA-T Fully built gt35r@28psi when i ge
why use a sr20det clutch? they are only 225mm just like ka clutch.
upgrade that thing! get a d21 pickup truck flywheel from a 91-93 and get a 300zx NA clutch! you will now have 240mm of clutch to grab! 25mm more does not sound like mutch but it is actually 40% more meat.
or if you want the best, you can do the baller setup (only setup that will hold my power) get a rb20det flywheel and put on a 350z clutch and you will have 250mm of clutch meat. it holds 550 wtq easily.
Florida240sx
I run a 400ftlb RPS clutch from Marty at injected performance (our sponsor)They got one higher than that too rated at 475
eazye2000
Car: S13 KA-DET
It's been around for a while, but it's been a pretty pricey setup. AMSperformance.com sells it. I'm not sure of who else though. But it's exaxtly what Drape said.
GriffinW
Car: 1991 S13 KA-T
you guys think inside the box with your spec nonsense. Im talking about Ogura, ATS, ORC etc...
