clutch install
hkssupratt1994
Car: 92 240sx hatch
im puting in a clutch so far i had the fylwheel resurfaced torgued the flywheel back down to 105 lbs with red treadlocker and i forgot to put back on the plate for the tranmission to mate with the back of the engine would it be allright if i just cut a slit in it to get it back on over the flywheel bcuz i really dont want to try to take it back off and what should the pressure plate and transmssion be torgue to?
thanks in advanced
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
Don't be lazy and do it right. I almost did the exact same thing, and noticed as we were putting the trans in. If you decide to cut it, cut the top of it, not the bottom as water and dirt will be able to get in easier.
karmakaze
Car: 98 240sx SE
i did the same thing and i was able to slip it over the flywheel without cutting or bending it badly.
but i have a HKS GD Pro Twin Plate. I don't know if that makes any difference in being able to get the gasket/plate around it.
Modified by karmakaze at 1:50 PM 9/13/2007
Modified by karmakaze at 1:51 PM 9/13/2007
Hijacker
Car: '92 240sx Convertible
'94 F-150
it's 6 bolts. not that big of a deal. just pull the flywheel off.
and as far as the pressure plate goes, so long as it isn't a special pressure plate, just tighten it by feel. And if you're threadlocking everything, exact torque numbers aren't needed.
Same thing with the trans. Just tighten the bolts down by feel and let it go.
If you absolutely have to have the torque specs, go download an FSM (conveniently linked in our FAQ sticky) and you'll have your torque specs.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
1.Pressure plate bolts get 25-33ft lbs
2.transmission to block bolts get 51-59ft lbs for the large ones and 22-29ft lbs for the smaller bolts..
hkssupratt1994
Car: 92 240sx hatch
i just put a little RTV on were i cut the plate so water cant get in
