p00t wrote:your not gonna like this but this is what i wound up doing...
getting transmission off... and everything was easy... flywheel bolts were on there real good, but i used a hydraulic jack shaft to squeeze between one of the pegs sticking out on the flywheel and the ground (to keep it from turning).
with 4 people under the car... we couldnt get the transmission back in no matter what we did... and peoples hands were getting cut on sharp transmission edges so i called it quits, and thanked them for trying. i then spent the next 1-2 hours with the transmission, 3 jacks, and tons of short wood 2x4's to use as shims so the jacks could reach from the ground. starter bell housing needs to be tilted down to the right pretty far. then you need to jack up the transmission it will go pretty easy until the part where its 1/4" - 1/2" away from goin in. I then just kept jacking up against the underbelly of the car with jacks in back of the transmission and front "wiggling" it up. it then popped in... and i almost **** my pants. i had just done it... i installed the transmission by myself... after trying tons of different orientations the clutch was in... its almost done!@@!@!
rest of the process went smoothly, underbelly of the car had a few scrapes unfortunately... but i got it in... and it worked. if i had to install a new clutch now i would get an engine hoist and take the engine and transmission out as a whole. the top right bolt on the transmission is impossible to get back on and torque down due to its position. i hate to leave things unbolted like that. but all the otherones went in.
MOST IMPORTANT THING if you decide to try the 2-3 jack method: dont let the input shaft take the whole weight of the transmission, you can have the transmission resting on the input shaft and a jack on the other end.... but NEVER let it take the whole weight of the transmission, if you bend it you are ****ed. GO SLOW, if you just keep trying different positions you will find one that it will sorta start goin in... stay with it, persistance. when it went in for me the starter part of the bell housing was about 40-60 degrees clockwise from its installed proper position.
encasemyheart wrote:Got it!!
Yesterday we worked on it again and couldn't get it at all, it sucked.
So this morning I went by myself and installed it. BY MYSELF and only one jack!! I was pretty proud of myself. Now everything is in, I just followed the advice here and did not end up loosening motor mounts or even jacking up the front of the engine. Just 2 jack stands holding p the car, myself and a hydraulic jack.
FYI I'm 20, weigh 200lbs and am about 6'2". I don't work out or anything like that so I'm not all that muscular. Just a reference for anyone else who may want to do this alone. I don't understand how I did it but myself and my dad couldn't get it after 5 days of trying. Oh well.
Thanks everyone for the help.
