Clutch install for 89-94 SR Red Top
speedracermage
Car: 1989 nissan 240sx
So i own a coupe. i have had Nissan for the like 3 years now and its been sitting for the most part. i wont claim to be an expert in cars at all. i have read the forum posting and technical guides.
i did my ka to SR swap in my drivewayi did my speed sensor swapinstalled and mounted and did the cutting for my FMICi decided instead of doing a battery relocation I'd buy a small racing battery that would fit next to my cold pipe.i installed my Megan racing FPR (doesn't work)i removed my EGR (it was in the way of my new exhaust manifold)I bought my aluminum radiator and electric fan and installed/ mounted bothI bought SAMCO hoses to bootI bought a dual cone intake for fun and looksI had Yury do my wiring harnessI installed my oil catch can
(i did all of it in my driveway)
Heres where any of you knowledgeable people come in. i have never done a clutch swap. what do i do...
i am about to do a shell swap.. (everything from my coupe into the new coupe that i am buying)
i figure since i have the engine and transmission out now would be a good time to do the clutch swap...
WHAT DO I DO... pics and step by step would be nice.
Hijacker
Car: '92 240sx Convertible
'94 F-150
It's not that hard >_>
- Remove transmission- Remove pressure plate- Have flywheel resurfaced if it looks worn/pitted/scored/blue (heated)- Remove old pilot bushing (you can rent a puller from autozone)- Install new pilot bushing- Place clutch disc on flywheel with alignment tool- Install pressure plate- Install new throw out bearing- Install transmission
scottydog
Car: 1992 240sx
Do a search. There are some good posts on this. Read the service manual also.
