s13orlando »
https://forums.nicoclub.com/s13orlando-u3524.html
Thu Oct 31, 2002 8:17 pm
That is why you take the box off. Run the hard line from the master cylinder directly to the slave, bypassing the box altogether. You can then direct bleed it at the slave in 5 minutes. The box and cooling loop are an after thought in design to help keep clutch fluid from overheating, instead it just traps air and causes problems.
__________________
Wow..I wish I had seen this post last weekend . That box and loop are causing all kinds of problems on my 1991 KA fastback.The clutch and hydraulic master and slave was replaced. All appeared fine. After the car is driven at highway speedsfor about 30 minutes the clutch won't disengage. I'm waiting fora hydraulic line to come in on 1/13/03 to bypass that block.Thanks,Bob,Orlando,Fl
