gingerbredman »
https://forums.nicoclub.com/gingerbredman-u67700.html
Fri Jul 25, 2008 9:49 pm
yep, the smaller one. it may be your slave cylinder, i've went through several before i finally stopped it from leaking. buy the clutch slave cylinder rebuild kit from autozone, cheap and just as good if not better than a new duracrap one. i eventually replaced my clutch master, bench bled it, and rebuilt the slave.
great pedal pressure (maybe a bit too much on mine ??), the clutch lines are squeaky clean, fluid stays pizz clear, and everything just works like it rolled out.
by the way, i strongly suggest looking under the dash (driver side) upwards of the clutch pedal to see if your clutch master cylinder is leaking, mine did. and if you only get a slave, or just a new master, then it likes to just wear the other one out. i'd go ahead and replace both, just me though. good luck
