Clutch help
jey_253
Car: 1990 S13 Silvia Conversion Rb25det
Im ready to order clutch for the soon to be beast. Anyone ever use eClutchmasters.....supposedly 450hp??? What are you guys running or would suggest
themadscientist
how much power you got?
jey_253
gnna bolt up the 2871 and tuning for 350-400
themadscientist
better start thinking about a metal clutch or an organic twin.
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
I am searching for a clutch to hold my build right now too. I have heard much bad about the eClutchmasters clutches either being difficult and impossible to break in correctly, and starting to slip rather quickly. I personally need a new flywheel too, so I am going the sr20 replacement route, and will be using an sr20 flywheel and clutch kit, with either the stock ca18det starter, or an s12 unit. Apparently, they will fit fine with a little modding to the bell housing.
themadscientist
here's what I had in mine
articzap
Car: 2014 F150 FX4
I have a KA 6 puck from ACT. Its rated at 426 FT/LBS. I'm sure that would hold fine.
jey_253
Anyone running the exedy stage 3. Been kinds leaning towards that one. yes, no, maybe?
