Clutch Help!!
90SRpwrd240
Car: 1990 240sx SR20DET
I'm having some problems with my clutch. Starting about a month ago the clutch starting slipping when I slammed it into 2nd. When this happened, I checked the fluid in the MC and it was almost empty. I refilled it and it seemed to stop slipping but the clutch didn't have the feel that it used to and had about 1-2" of play at the top. I bled the system and this fixed it immediately. Now after only 2 days it is starting to get soft again on the pedal. The fluid is at about half but I cant find where it is leaking. Any ideas?? I have checked all the lines and the slave which is only about 6 months old because I replaced it. Clutch is a Exeedy Stage 2 with about 1 1/2 years on it. I know the clutch isn't bad because when it is bled and full of fluid it grabs hard. Any help is appreciated.
keepitsidewaze17
Car: 1990 nissan 240sx
same thing happened to me i replaced the slave cylinder and all is well there like $15 at parts store
90SRpwrd240
keepitsidewaze17 wrote:same thing happened to me i replaced the slave cylinder and all is well there like $15 at parts store
I guess I could try that again, but like I said it was replaced about 6 months ago right before the winter so I don't think it would go bad that fast. Atleast that would be a cheap and fast fix. Anyone else?
aziankingz
Car: 1990 240SX SE
did you bleed the clutch after putting in new fluid? maybe you have a leak in one of your hard lines?
90SRpwrd240
aziankingz wrote:did you bleed the clutch after putting in new fluid? maybe you have a leak in one of your hard lines?
Yeah, it was after the new fluid. It really sucks because I can't see signs of leaking anywhere.
Rucca
Well obviously it has a leak somewhere. Just keep looking. Maybe have someone pump the clutch while you look to try to expose the problem?
Either that or just keep the MC topped off. As long as it doesn't get low enough to suck in air it will still give a decent feel (unless the leak gets worse).
nismotuner1
Car: s13 Hatch
05'Titan
Is it leaking out of the back of the clutch m/c down the fire wall? thats the only thing I can think of if you checked all the lines and the slave is not leaking.
scottydog
Car: 1992 240sx
Check the floorboard under the clutch pedal, and under the rubber cover of the slave cylinder. The leak is there somewhere...
90SRpwrd240
nismotuner1 wrote:Is it leaking out of the back of the clutch m/c down the fire wall? thats the only thing I can think of if you checked all the lines and the slave is not leaking.
Yeah, I'm going to take a look under there today, finally have some free time. If this is the case and there is a leak down the firewall, I'm assuming that the Cluch MC is bad and needs to be replaced?? Thanks for the help guys I appreciate it
justy90240sx
Car: 90 240sx se, 95 240sx, 92 300zx
lets us know but im sure as those guys told u the clutch mc is most likly leaking inside your fire wall its common place to leak
90SRpwrd240
justy90240sx wrote:lets us know but im sure as those guys told u the clutch mc is most likly leaking inside your fire wall its common place to leak
So after checking it out, that is most definately the problem. It's leaking right around where the shaft gets pushed in by the pedal. Picking up a new one tomorrow. Thanks for all the help
