Clutch help
ralphsdiorama
Car: 1991 240sx, 1998 240sx (RB project)
I just installed a new clutch for my sr20det swap and the pedal only engages when you push it half way down. Then the pedal gets stuck half way and sometimes shoots back up after being stuck for a little bit. Is it possible I put my clutch disk on backwards? Thanks
S13240
Try bleeding the clutch system first and then get back to us.
xero1
Car: 08 Altima Coupe
adjust the clutch master clinder rod, make sure there is no air in the system.
