Clutch help part 2
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Got the slave put on the S13 and it wasn't leaking anymore and bled the system and theres no air left. Problem is theres only a little pressure on the clutch pedal. I don't know what else to do now. I'm lost and need some help. With there only being a little pressure, does it mean theres still air in it somewhere? Any information would be grateful.
BadMojo
Car: 2007 Mazdaspeed 3
If there's no leak in the system, I'd say, yeah...there's still air in there. Do you still have the stock dampener box or did you bypass it?
NSR_s30
'71 Datsun 240Z
Still have the damper box....
BadMojo
NSR_S13 wrote:Still have the damper box....
Everyone who has ever had to bleed the clutch has commented that the stupid box makes it VERY VERY difficult. You might want to try to bypass the box by either getting a stainless line from somewhere like SPL. Other folks bypassed it by bending existing lines.
In lieu of that, just keep bleeding it.
NSR_s30
'71 Datsun 240Z
How hard is it to get rid of the box? Thanks thus far for all your help.
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
Have you changed the Clutch Master Cylinder? I know almost everytime I had to put a slave cylinder on the master was soon to follow.
nismostate
Car: all sorts of motorsports
really? i didn't know that... i've never changed my master cyl and i have 206k! of course bought the chassis used. how do i know if it's about to go? i already got a new slave when i did my swap
fiznat
Car: Grown up :(
taking that box out is REALLY easy, just unscrew the hard line that goes into it, and attach that to the rubber line that comes out of the slave cyl. You have to bend the hard line a little bit to point it in the right direction, but its really extremly easy. There is a website around someplace that has pics and directions, but honestly its just unplug, bend, plug in-- not hard at all.
EDIT: also did you remember to re-install the push rod from your old slave cyl? I forgot that the first time and the pedal was really weak/fluid poured out the end of the slave's nipple.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Josh, when we eliminating the box and getting this thing done? I wanna get that car on the road as bad as you do. Let me know.
SeVa-S13
Car: '05 GTO 6spd
The master cylinder shouldn't be a prob, just eliminate that dampener by bending the line and be sure to bleed it properly (2 people). In case your slave cylinder didn't come with directions, you loosen the bleeder valve by the slightest amount, you can often hear a little squirt noise. Pump 3 times, close the valve, pump 3 more times. Repeat this about 5 times to be thorough and you should be set. Good luck.
NSR_s30
'71 Datsun 240Z
First slave I bought was leaking from the dust boot. So we ended up getting another one. So getting rid of the box is easy? Know of any links with instructions? From what I heard, w/o the box it makes everything way easier to bleed. I don't think my mast. cyl is bad. Thanks for all your help guys.
sleepyRPS13
Car: to sleep
NSR_s30
'71 Datsun 240Z
You guys are fooking awesome ! Thanks for all the help and the link sleepyrps13.
