Clutch goes out in 2 days???
w00t_Masta
Well, i fell like my clutch is going out but i think that it is something else. You see when i push in the clutch there is almost NO pressure, where u used to have a descent amount to just get the thing down past the pressure point. Would this mean the clutch is slipping and i need a kit? Or could it mean that i might have a hose that needs to be reaplaced or somethign of that matter because it doesn't make sense that the pressure would dissapear.
Thought i'd check w/u guys b4 i just bought a clutch. But imma also go to the local clutch place and see what they say. Going to dinner and lookin forward to your thoughts.
w00t_Masta
High Plains Drifter
Try pumping the pedal to build up pressure. You may have air in the line, or either the master cylinder or slave cylinder is shot. Look for leaks around the boot of the slave cylinder too. Not difficult to change, just messy.
