s13drft89 »
https://forums.nicoclub.com/s13drft89-u31033.html
Mon Jan 02, 2006 10:34 am
I had the me probem just with mine, my master was leaing from inside the cargo(where the pedal is at). I changed the master, an i said what the hell as well as the slave. If your slave was not working, or leaking, you should be able to take it back for another one. Also i believe on the master there is rubber gromments or grommets, anyways take of the canister, which holds the fluid, and see if those two are letting in air, and or if there still good. My thing on my car was that i would keep on trying to bleed the slave well, once i would go up to pump it(if i were to push fast) it would fell good, but once i say i let it sit for about 5-10 seconds it would just drop back down. Also has Chezedik try to bleed the actual slave. -Ricky
