CLUTCH FORK STICKING
blonka
Car: 180sx ca18det
Hey, my clutch is not fully engaging as my clutch fork is getting stuck right before its fully engaged. I can tap it with a hammer back into place but then it just gets stuck again.
any ideas how to fix this? oh and its not the slave as I can push the push rod back in.
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
throwout bearing carrier sticking on input shaft collar. remove trans, remove throwout bearing asmbly and fork, clean the collar the bearing carrier slides on and clean the inside of the bearing carrier, lube collar with anti seize or brake grease and reinstall all parts/trans. remember to clean and lube the pivot ball too
float_6969
Or the pivot ball is broken. Very common problem. I've done it to 3 of my S13's before I finally replaced it with a NISMO unit. I've never had a problem since. Regardless of which one of these problems it is, the transmission is going to have to come out.
