NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sat Oct 18, 2003 1:33 pm
sounds like the fork pivot inside the clutch area has broke off. have seen this happen couple times. pull the fork and boot out and look in there with a flash light about 2 inches in you should see a 17mm stud coming out from the trans front cover. it should have a round top on it if the round area is not there look for it between the spring and the fork. if it is on the fork it has broke only way to fix it is to remove the trans and remove the old pivot stud and install a new one.
