Def »
https://forums.nicoclub.com/def-u8646.html
Thu May 27, 2004 8:47 am
More bad news from my newly acquired beater.
So the clutch would not disengage, and there was barely any resistance on the clutch pedal, with the pedal not even really coming up from the floor. It would not shift into gear while the engine was running, since obviously the clutch is engaged.
Last night I put in a Stainless steel braided line and bypassed the clutch damper box thinking that it is was alot of air in the lines. Bled the lines, and not really much change.
What I've found is that the lever/fork going into the transmission that is moved by the slave cylinder is offering basically no resistance. It doesn't have any vertical movement(i.e. it doesn't move in the direction it's not supposed to), but I could pretty much keep the lever all the way depressed after my friend pressed down the clutch pedal and the slave accuated it.
To me this looks like a problem in the mechanisms that release the clutch. The hydraulics are fine, all bled. The slave seems fine, and it along with the master cylinder are supposedly new(guy did work on it before I bought the car). There is supposedly a new clutch kit installed as well, but no idea how good of a job he did.
Someone else was driving the car when it first broke down, and he said it got progressively harder and harder to shift. So that kinda points away from it being the fork pivot since I'd think that'd be a catastrophic failure.
What about the throwout bearing? Is it possible it fell off the fork, or seized up or something to that effect?
I'm not currently debating whether or not to pull the transmission and try to fix it myself with limited hand tools, or taking it to a mechanic. I'm 99% sure I'm going to do it myself, but I've never actually pulled a transmission before by myself, and I'm not all that familar with this car so far.
Bleh, the car didn't even run for 3 weeks after I bought it...
