Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Sun Sep 28, 2008 6:20 am
Well I take my car to the shop since I was fed up with it.They were supposed fix some electrical problems.The reason why the car wasn't running was because of a bad ground.And It was running crappy because of a POS hose on the IACV/Air regulator.
So they are almost done and then they go to move the car "Supposedly" and the clutch pedal goes to the floor.So they check the hydraulics and they're all fine.Then they pull the slave out and remove the rubber boot from the Clutch fork to find that the Clutch fork pivot ball has broken.........
I have a upgraded clutch in there, that doesn't have CRAZY Clamp load on it.I don't know how much it has but its a bit more than stock, plus I had the Fulcrum moved on it.This car has only been driven ONCE.I've probably stepped on the clutch to start it 100 times.Now is it that I have just that luck where they stepped on my clutch that ONE time to start the car and the Clutch Fork Pivot breaks?????????
On to the fix.
Well since I have Top Hat Mounts the whole Engine/Trans Package needs to come out to pull the Trans.I don't have a lift or a engine hoist, nor do I have the room to do this swap AGAIN!!!!!They want to charge me $800 to do this job, or $450 if they can just loosen the mounts and tilt the engine.
Is there any way of changing the Clutch Fork Pivot Ball without taking the trans off?????
At this point I'm soooo fed up with this car I just want to sell it.But.... I'm soo deep into this car that If I do sell it that I would be TOTALLY UPSIDE DOWN on the sale.
Any thoughts or Advice would be much appreciated!!!
