clutch for my 240sx
scherger_16
Car: 1990 240sx SR20DET, 1993 Nissan D21 pickup
im looking to get a dual friction centerforce clutch for my 240sx with the sr20det motor and transmission. i cant find anything for listings on there site. does any know if you can get one or would you sugest something better. mostly gonna be using it for drifting and drag racing but i also use it as a daily driver some times. engine is mostly stock but im looking to do some upgrades next spring so will need to get something a little bigger for clutch rather then just stage one
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
clutch is the least of your money worries sire...id think first on what power goal your looking to get out of your engine..and start buying parts bit by bit..then worrie about the clutch later..good luck.
scherger_16
probly some where around the 300hp mark and the reason i need a new one ic mine is slipping otherwise i wouldnt be concerned about my clutch right now
MACAuto
Car: '89 240SR Track Car
The RPS Street Disc MAX kit (non-puck street type disc) is very good for all-around driving. For drag or drift, try the Exedy Hyper Single, which is a puck type clutch, and includes a lightweight flywheel. Both will work very well from stock HP up to about 425 HP - choose by usage.
MACAutoParker, CO
