clutch for ca transmission
cuzan0
need a clutch???well i just installed a performance clutch on my car 6-puck with spring from a S12 84 200sx ca18et motor and it is a direct bolt on no modification what so ever!!!
Darrell
float_6969
The whole assebly was for an S12, or just the pressure plate?
cuzan0
the pressure plate,clutch plate,throw out bearing and pilot bushing all fits no mods.
khrys771
ca18det, S12 clutch kit and the ca18det transmission in the s13 240? fits no mods?
cuzan0
yes any performance or stock clutch kit from a s12 84 200sx turbo (ca18et) will fit a ca18det transmission with no mods
darrell
float_6969
Thanks for the info Darrell. I'll use that in the future. It's really easy to find part for S12's. You can also get stuff from a 1984 Pulsar.
khrys771
what are the ratings on the stock s12 clutch?
cuzan0
i am not using a stock s12 clutch.....i used the specs. (year make and model) of an s12 turbo so i could get a performance clutch..
darrell
khrys771
well i am only going to run the CA stock when i get it, so i really don't need a performance clutch. i only plan to have 225hp.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
are you sure? the one i tried didn't work(i worked at a parts store about 3 months ago) the only one that i found to work was for an 85-86 stanza with the ca20?
khrys771
someone with the money and a CA needs to try this please
cuzan0
yes it does work,cause i did the install yesterday.it works (I work as a mechanic for a living)and i know it works,and also the pressure plate it only goes on one way,you can't just throw it on you will need to turn it until you match the right bolt holes and put the dowl pin in the right hole.the info i told my vender what i needed was a clutch kit for a ca18et thats from a 84 200sx turbo and N1ceDrgn was at my shop while i was installing the ca18det transmission to the ca18et clutch kit..
darrell
float_6969
And just to emphasate it, the pressure plate will only go on one way. The first time I ever tried to change my clutch, I went to the parts store 3 times returning my clutch and getting a new one cuz "It didn't fit". Finally one of the older guys there said, "You do know that the pressure plate will only go one one way, right?" I was like, "Um... Yea, I knew that..."
ca18datsun510
wow, you're a mecanic? please, give me a moment to bow down and honor your almighty glory. sorry sir. please, beat me with a bamboo stick for not having your mass of knowledge. yes, i know know the pressure plate goes on one way. that doesn't actually apply to all cars though.
float_6969
that was a little outta line don't you think ca18datsun510? He was simply making the statement that he had experience with cars, and that some people (like me when I was younger) weren't aware that the pressure plate will only mount to the flywheel one way. I know that he didn't mean any insult by it at all.
USDM_OneVia
Car: Racing
Spec makes clutches just for the RWD CA's.
Also... if anyone needs one. I am selling my Spec Stage 1 for a RWD CA. 285 to your door. Brand new in the box. I want a Stage 3, so the stage 1 has to go.
Joe
cuzan0
ca18datsun510 wrote:are you sure? the one i tried didn't work(i worked at a parts store about 3 months ago) the only one that i found to work was for an 85-86 stanza with the ca20?
the reason i said i am a meachanic is because you were saying you worked at a parts store,well anyways forget it. no use of calling people names here. all's i wanted to do was to tell people here if they dont have the money to go out and buy a performance,and want the car to run already then they can go out and get a O.E.M stock aftermarket clutch kit or find a performance one to there budget like i did bought my clutch for $200 shipped
darrell
ca18datsun510
thats cool man, i apologize for getting out of line if i insulted you, i can honestly say that a 85-86 stanza with a ca20 does also fit, perhaps the clutch i had at my ****ty store was mislabled. there is a reason i dont work there anymore, the store sucked, and i was the only one there who actually works on cars. im not a mechanic, but in the last 2 years i have done quite a few motor swaps. gsr into ls integra, 2 350's into s10's, a 5.0 ranger pickup, jdm mazda v6 into a probe gt, ca into a datsun 510(still ongoing) soon putting an sr into my 240...not to mention just replacing stock motors and transmission in friends cars and i cant forget about the yamaha 750 street bike motor into the yamaha blaster
drumma022
Yea, SPEC has a listing at specclutches.com of the specifications and last I checked, Enjuku had them in stock.
I also have a CA18 4-puck unsprung disk laying around if anybody wants to take it off my hands.
RayAIM: godzilla240sx
CA19DET
Quote »I also have a CA18 4-puck unsprung disk laying around if anybody wants to take it off my hands.
[/quote]what the specs, THATS A STAGE 4??
cuzan0
i can get any stage clutch kit by hyperclutch from full disk to 3 puck metalic sprung or non-sprung pucks for a ca18det for 289.00 shipped i am using a a 6 puck sprung kit wich looks like this pic of clutch kit and thats what comes in the kit you'll have to press out your old throwout bearing to install the new one thats the only mod you'll need to do.
darrell
CA19DET
Quote »i can get any syage clutch kit for a ca18det for 289.00 shipped[/quote]what brand?? SPEC??? if so i am looking to buy a stage 3.
CA19DET
ok you edited it..
khrys771
ok so, the CA18ET and stanza CA20 clutches will fit.
USDM_OneVia
Car: Racing
Judas Priest people.....
Buy a CA18DET clutch for your CA18DET.....
It's a simple as that.
Joe
khrys771
are you putting this on the list?
quest
cuzano,so you gonna supply them ? I see no source, other than "your supplier".Post or shoot your email if so. mine: [email protected]Any ratings ? What kinda power u putting thru it.... or gotta "break-in" ?I'd think "Hyperclutch" is the manufacturer ?Its good to have alternatives
Anyone lighten their oe flywheel ? Effects ? who did it ? $ ?
Vetal
cuzan0 wrote:i can get any stage clutch kit by hyperclutch from full disk to 3 puck metalic sprung or non-sprung pucks for a ca18det for 289.00 shipped
What can you offer for some ~270HP ? Don't think I'll make much more in the nearest future...
