clutch/flywheel reccomendations?
chmercer
i want to replace these but im not sure what to buy. i just have the oem clutch in there right now and its starting to get hard to shift like its not engaging. anyway, i guess the heavier duty pressure plate you get the harder the clutch pedal is to press? also, can somone try to explain how like a 3 puck clutch or somthing feels in comparison to a standard street clutch? also, looked at nismo clutch kits, seriously expensive. Im looking for somthing good but not like a million dollars. i think around 500$ is the most i could possibly spend. thanks for your help guys!
zachosz
Car: NONE!!!
If it's hard to shift it's probably your clutch master/slave cylinders. If the clutch doesn't slip then you don't need a new one.
Good aftermarket clutches are ACT and Spec (not sure about the quality on the Spec one), flywheels are Unorthodox Racing or Fidanza, maybe even Mueller. Clutch kits are ~$300, flywheels from around $450 and up.
Do a search, there's a lot of info on this...
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
i just put in a spec stage 3 6 puck clutch it is a little rougher to shift but not that much. I ordered thinking i was getting a 4 puck but they sent a six but its still sweet. i got mine from enjuku for 315 shipped.:cool:
Daunttless
ACT/JUN. : )
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
From my personal experance I dont like centerforce. If I go out and have a little fun after 10 or 15 min. it won't chirp 2nd any more. So I say spend the extra money and get a good one.
