jt15833 wrote:*Using red loc - tite on the bolts, thread in by hand and torque to 72-80 ft lbs, i was going to do 80 because i don't want them backing out, would there be a reason to torque more in the middle or lower on the 72-80 range?*Torque the bolts in a cross-hitch style holding the crank bolt to keep everything still
Clutch Install*Torque to spec in a cross hitch pattern (loc - tite?)
you ought to do those in stages. anytime you're tightening anything over 30-40lbs, its a good idea to go in stages. Torque all the bolts in a star patern at setting one (say 35lbs). Then, once all bolts have been torqued to the same setting, tighten them again (normally i go to the lowest spec either the 1st or the 2nd time, depending on the spec). Lastly, if you want to make sure they stay on, torque them to either mid range torque spec or the maximum torque spec.
I've never used loctite on any bolts on my engine and i've never had an issue with them backing out.
