Hello,
I'm about to do an sr20 swap and I'm thinking of replacing the clutch and flywheel at the same time. I've seen a lot of posts on the internets of daily driving becoming an issue when replacing it (noise, rough engagement, pedal feel?) What clutch/flywheel will maintain good daily drivability and handle just under 300hp? Should I get a kit? Just the clutch? Just the flywheel?
I'm looking at the following:
1. Exedy hyper single clutch kit
2. Exedy stage 2 clutch and Exedy NF02 Light weight flywheel (14lbs)
3. Exedy stage 2 clutch and Fidanza flywheel (11lbs)
Thanks!
