clutch fan vs koyo 210?
Fenvy
Car: 2005 350Z Base 6MT
has either one proven to be better than the other at cooling? 75% city driving and 25% highway
the socal summer is really killing me
Nismo_Freak
Car: 89 Nissan 240SX
I think you mean FAL210
I would get a FAL150, it flows more air and takes less amperage. Hey it's even cheaper, and I own one for those reasons.
The electric fans will work better, provided you have them setup correctly.
If you wanted budget you can opt for some OEM fans from the FWD cars.
Fenvy
can you eleborate on "have them setup correctly" ?
Nismo_Freak
Loveless wrote:can you eleborate on "have them setup correctly" ?
The thermostat switch.
Some people don't bother and just run the fan constantly. Fred's old S13 did this and it was a pain to keep warm even on 60 - 70 degree days.
Fenvy
I live in socal
the usual temperature around here is 80 and 90 ish during the summer
fal 210 + koyo isn't doing it for me. the power is directed connected to the ignition
I remember reading something about clutch fan > fal due to the shroud set up
yesterday, while in a shop, 2 people who has redtop and clutch fan said they don't an issue with clutch fan
Nismo_Freak
Loveless wrote:I live in socal
The FAL 210 isn't that great of a setup for RWD cars where you have the space for better fans. They were designed for FWD cars where spacing between the turbo and the radiator gets tight.
I don't understand how you can have an issue with overheating with mild temps like that. I think you need to re-evaluate your setup in terms of mediating airflow to the radiator.
S13240
80-90? Try coming to the desert and experience the 100+ degrees here! Anyhow why isn't your combination cutting it for you? Overheating? Aftermarket coolant temp gauge?
I have these small spal fans that doesn't even look efficient compared to stock sentra e-fans and I have them on constant and no problems here. My coupe that I sold to my brother ran that same sentra e-fan setup on a koyo radiator with no problems and I installed the stock fan shroud + fan on there and runs the same. No difference at all.
Fenvy
sorry, I meant 90 to 100c of late
the ecu registered averge 85C from the stock sender and 90c from the hot radiator hose
if I run it for too long in the afternoon it'll get to 90c from stock sender and 100c from the hot radiator hose
Nismo_Freak
Loveless wrote:sorry, I meant 90 to 100c of late
What kind of coolant are you running and what mixture?
Explain your entire heat exchanger setup (I/C, Rad, Coolant Mods, etc.), and your typical drive where it hits 100c.
bruinbear714
Actually, a Koyo radiator + FAL-210 + a way to control those fans (like the Greddy Multi switching system, or the HKS fan controller) is a good setup. The stock fan controller that comes with the 210s is pretty crappy and everyone I've known had problems with that stock controller.
Fenvy
Nismo_Freak wrote:What kind of coolant are you running and what mixture?
not sure what you mean by explaining setup, you mean list of my mods?-replaced oem thermotstat a year ago-fal twin fan connected to ignition-koyo aluminum radiator-samco silicone coolant hoses -25% coolant 75% distilled water + redline WW-ngk iridium cold plugs-greddy fmic with stock present, not much air flow to radiator since ac condensor is in place
if I get to drive fast on the freeway I don't have much a problem, but my driving is mostly restricted to stop and go traffic, a lot of idle times, usually that's when the heat rises
would retard/advance timing be a tempoary fix for my problem?
spider_slayer
Car: S14 240SX
S13 240SX
just take out your a/c condensor. i did and my car runs about 10 degrees cooler.
and don't say its to hot out there cause i live in kansas and it was 104 today.........
mr. silvia
Car: anything doing with cars
i had a perma cool fan in my car and i kept having a problem with my car trying to over heat, in stop and go traffic.. and thats with out my ac on.. with my ac on i could go maybe 20 mintues and it would over heat.. i got rid of my perma cool fan and got a 92 ford taurus with 3.8 fan. and now i can run around all day with my ac and my never over heats. and that in 100 + heat. trust me it pulls some major air.. and only costs about $50 at the junk yards
NoOneBetter
i have the FAL210 + Koyo radiator setup and it runs fine. I live in Socal
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Fan thermostat = super duper easy to install
If you dont have one its only because you are lazy
kuramaya
Car: 1995 RPS13 180SX
Clutch fan definetely has to go, I am changing mine out soon. Dont get the slimline fans, I have (2) buddies that have had bad experiences with them..1 motor shot after a week and the other caught on fire....Primera fans are what I am going to use. I have a couple buddies using them. SOmetime they are easy to find in the junkyard and fit well with Koyos and S13/14 Radiators...just my.02lateDaryl
