If you could get anywhere NEAR those figures, every manufacturer would have engineered electric fans into every engine, as the mpg savings would save them tens of millions in government fees......obviously the savings are nil when you consider the extra draw from alternator created by the additional load the electric fans draw. And 10-25 horsepower???? The a/c compressor does not even use anywhere near that.....a clutch driven fan certainly uses less than the compressor,especially once at speed and it is freewheeling.bullittandy wrote:Swapping an electric fan for mechanical is usually worth 10-25 HP and 1-2 mpg.
It is a very worthwhile trade but electric fans are a little less reliable (at least temp sensors are and fuses that go with the fan) and it requires a little extra engineering.
i don't know anyone on the board thats done it-I've always wanted to but. . .
You are partially wrong. Air moves through the radiator when you are moving. When the fan is off, the benefits are free revving, better gas mileage and more power.Paul Wall wrote:Hate to be "that guy" but many people have asked this and everything they get the same answer. With a electric fan the alternator has to work harder which negates any possible benefit...
almost every car that comes in my shop has an electric fan from the factory. Benz, BMW, Infiniti, Audi, Jaguar... etc. Those are usually easier to service.The ones with mechanical fans are usually the base models. Its a lot cheaper to make mechanical fan setups.qship96 wrote:
If i'm bored, I'll test how much hp is lost from the mechanical fan, I'm going to the dyno in a few weeks again to see how much i have gained from the manual transmission swap.bullittandy wrote:Swapping an electric fan for mechanical is usually worth 10-25 HP and 1-2 mpg.
Up till 2002 The Q45 used a viscous fluid type fan. So I find it somewhat insulting that you reference the 1990-2001 Q45 as a "base model".subtle_driver wrote:
Pretty bold statement. every part in a car will fail sooner or later. I have read numerous posts right here of members fan cracking and pulling apart. Mine did. In fact if your oe fan is old go look at it for cracking. Plus the guy who started this post said his needs done. go electric, I did.Paul Wall wrote:no OEM fan has exploded.
Not everyone posts on forums. I haven't posted all the modifications and results from my countless projects and customer cars.Paul Wall wrote:True but so far in the history of NICO and maybe even the Yahoo board the fan on a Q45 has stayed together.
Dennis's Q would be the real test.
I own a 1990 Q45, I'm not insulted that Nissan didn't use an electric fan. I love Base model cars! they are cheaper, faster, more simple, and lighter and have less probelms. I'm just happy to get rid of my cracked unit and install an electric fan instead.Paul Wall wrote:
In order to move 25 horsepower worth of air with an electric fan, you'd need a fan motor that consumed roughly 30,000 watts (assuming 60 percent efficiency) - or around 2,200 amps at 13.8 volts.bullittandy wrote:Swapping an electric fan for mechanical is usually worth 10-25 HP
By Q45TechThe stock fan is very efficient since it has a temperature controlled clutch my guess is it uses 3 HP at 6,000 rpm and maybe 1 HP at
2500 rpm. To make power for an electric fan the alternator must draw more HP from the engine thus you have the two additional
inefficiencies to contend with so it would be less efficient than direct drive under most conditions. Electric fans are used on front
wheel drive where the engine is sideways or where they want to shorten the space between the engine and radiator because of
packaging problems. Electric motors wear out much faster than direct driven units.....some LS400 uses hydraulic fan
motors driven from power steering pump. After 7 years the plastic blades do crack at the hub the under $100 blade is easy to replace!
