Clutch fan destroying fan shroud????
2forty
has anyone had this problem? I have a koyo radiator on my SR and mounted the stock fan shroud. After some driving, i went to check and make sure everything was ok, and i notice a decent sized gash in my fan shroud. Seems it was hitting.... and ate away a bit... few days later, gash looks a tiny bit bigger, so i thought nothing of it. Then i noticed im missing a blade off my fan! geezus! feels a bit more wiggly. could that uneven fan cause some unbalance? anyone ever had this problem?
wildacexxx
Car: 2002 Q45 nav sport
wat you are talking about doesnt sound safe at all for your radiator. my suggestion is that u put in an electric fan or a replacement clutch fan before u bust ur rad and over heat.
silvia-junkie
Car: s14 kouki
an un balanced fan can cause turbulance and put extra strain on your water pump
mmashburn
Car: 1992 240sx
sounds like it's time for an electric fan...
DawgMode
Car: 180sx
hope one of the blades dont shatter and **** up the new radiator
574-240sx
Car: Nissans, Toyotas, Subaru
Yes a plastic blade will easily puncture a radiator, I have had it happen before.
2forty
well got altima fans now still kinna need to figure out the wiring, i think its on low speed :-\ o well, im sure the koyo and nismo thermo will help keep it down a bit.
sunnys14
Car: S14
i think you should get a KA swap
