Clutch fan damage, how to fix?
Loofee95SE
Car: u gota sister??
Hey peep, how hard i sto fix SR20DET with Clutch fan damage??I'm looking @ this SR from Jhot. and want to know how hard is it to fix, and who have the parts?? how much?? Thanks in advance C
Loofee95SE
hmm, viewing but no reply.....-_-
dj_lennon_franz
Car: 1992 240sx
get rid of the fan and get dual electric fans...ull wind up doing this anyways if you race the car at all
ride4lame
if you don't know how to replace a fan, maybe you should have someone else do your work....no offense meant by that though
replacing a fan is super easy if its only the fan
SpeedRacer1
Car: 1990 240SX, G35
If the fan is broken, buy a used one on ebay $10-20.
MadSideways
Car: Cars, women, drifting...the usual...heh
It is not required if you remove it and go with twin-electric fans mounted to the radiator. You'd gain some parasitic hp back anyways.
240dreams
Car: 240's
maybe a ka fan might work. they look almost the same.
rudee023
Car: '03 Infiniti Q45
I'll sell you my stock cooling fan. I just upgraded to flex a lite duals. $20 plus shipping.
SpeedRacer1
240dreams wrote:maybe a ka fan might work. they look almost the same.
The KA clutch fan does not work because the clutch is about 1/2 inch to inch shorter than the SR clutch. This means that fan will end up hitting the lower radiator hose to shreds and anything else that gets in the way.
However you could use the KA fan and on the SR clutch and might be able to get away with it. The KA and SR fans have different depths and fan patterns.
