it had been set up nivce since i changed the clutch (and tob sleeve, etc everything)
there was a couple threads of the pushrod sticking out at me from under the dash and the ascd bolt was right out of the car i believe.
\how the f*** do you get this clutch to grab quite close to the floor, because
if my adjkustment rod is ANY LESSS than FULLY threaded into the master cylinder with no threads sticking up, my clutch is soft s*** and then if its out all the way it actually hold the presssure and gets stiff while driving and then engagement is up at the top of the pedal.
i changed the slave brand new oem lately and f*** i bled it a LLOOOOTTTTT
also rebuilt MC and i only have the option to get a brand new cylinder (depending on the advice im given here,maybe i dont need one?) and then i thought maybe loosen the pushrod and then bleed from the setting that leaves the pushrod sticking threads out at me
would that be the answeer there^ as far i know the best way to bleed was always with the pedal to have maximum travel but its just not gonna hold pressure unless its extenmded fuilly
please help and im sorry for punctuation, im on the phone at work and need to get the f*** thing working so i dont eat any more brake fluid
