S14KoukiMonster »
https://forums.nicoclub.com/s14koukimonster-u36640.html
Wed Feb 01, 2006 9:45 am
Hey man,
I aprreciated the 300zx brake link you left me(under my other name S14 Jordan that's on my work computer), that was EXACTLY what I needed, thanks.
Regrding the bleeding of your clutch, the procedure is as follows-
(monitor brake fluid level @ clutch m/c-obviously)Connect transparent tube to air bleeder valve on the clutch operating cylinder(slave cyl).Fully depress clutch several times.With pedal depressed, open bleeder valve to release air, then close valve.Repeat those steps until brake fluid flows from bleeder valve w/out air bubbles.
I assume did that?But you made no mention of the next step.
Now release air from the bleeder valve at the CLUTCH PIPING CONNECTOR using same procedure as listed above.Repeat procedures until desired feel returns.
IF APPLICABLE-When replacing your clutch tube, install the new one parallel to your under body floor panel. If you don't, bleeding might be a beatch.
I hope this can help, I think this post might be a bit old so maybe you already did this. But when I saw you made a post I wanted to help you since you helped me with my z32 Q.
Jordan
