Ok motor is running great and idles at 800 rpm. Went to disengage the clutch and I have to put it to the floor to get it to release. So I figure I'd bleed the slave cylinder. Did it no bubbles. All new fluid. I can see the slave moving but it doesn't look like the fork is moving all that much. The slave cylinder moves and extends but I couldn't tell you how far. The rubber boot looks like a three ribbed accordion and it extends out so that all three ribs extend but not a whole lot.
I searched and found how to fix the pedal adjustment of the master cylinder.
Now if that doesnt work what should I do next?
Btw I can hear what sounds like the tob making noises due to the clutch not fully disengaging. Also if I let up on the clutch(after being fully depressed) just a bit the clutch fully engages causing it to stall out
