Clutch Diameter
Doogz
Car: '89 240sx coupe
Quick question, I was trying to find the diameter of the stock CA clutch and the only thread i found was one that stated it was 9 inches. Now, its been awhile since i've had the clutch out of my car but 9 inches seems a little on the small side. Can anyone tell me what the diameter is?
cortina-mk1
Car: GT-R Skyline, MK1 Cortina's
11 inch flywheel10 1/2 inch clutch
Doogz
Now that sounds much better! Thanks a ton.
Jezz_s13
Car: Sil80 Track Car
clutch plate is 225mm
Doogz
225mm's is not even 9 inches....now you guys are confusing me again!!
cortina-mk1
well all i can say is that my clutch that we have on standard CA18det here are that size
keep in mind these are RWD not FWD maybe that is the difference you are talking about
Doogz
I am definately speaking of a RWD CA...
cortina-mk1
heres a pic for you to hava look at
oh BTW it says im only allowed to post pics 300x300 is this right ?
Doogz
What kind of a crazy *** setup is that?
cortina-mk1
..." What kind of a crazy *** setup is that?..."
im not sure i follow you... whats crazy about that? :)
NeedCAforS13
Car: CA swapped S13 coupe
yeah... thats about what mine looks like. but without the red cover;)
http://www.nicoclub.com/photopost allows you to upload any pictures you want, then you link them to the thread:)
Sean
cortina-mk1
oh ok thanx fer that sean
knightrider
Car: black 90 240 coupe
ca clutch disk is 225 mm, the same size as KA clutch.
float_6969
That looks like mine, except mines blue...
cortina-mk1
will measure the an old clutch plate and let you know
knightrider
no need, its been said, its a 150mm inside diameter, 225mm outside diameter.
Doogz
cortina-mk1 wrote:..." What kind of a crazy *** setup is that?..."
Referring to the pressure plate. ACT is yellow (even though they don't really make a CA kit) and im pretty sure SPEC is blue, so the only other options that i know of for the CA are really expensive. So i was wondering what kind of crazy setup that is? As in who makes it?
cortina-mk1
@doogzits a daiken exedy based clutch but has been modified some more by a australian clutch specialistthey are usually purple color
cortina-mk1
heres a few pics of a stock RWD CA18det clutch
cortina-mk1
another one
Jezz_s13
The RWD CA is definately 225mm.
here's a couple of pics,
a stock disc...
the gouge cut into my flywheel by my AP paddle..
The bit from the manual...
Doogz
cortina-mk1 wrote:@doogzits a daiken exedy based clutch but has been modified some more by a australian clutch specialistthey are usually purple color
Sounds like a nice setup. I hope you're putting some power through there to let that clutch stretch its legs.
Thanks a bunch for all the info guys....but seriously, i wanna see some tattered and torn, beaten to death clutches on your CA's. You guys are babying those things! :)
cortina-mk1
@ jezz_s13those specs from the manual are different again to our manual here is australia
i think the ca18de is a smaller clutch than a CA18det
anyways... thats the size clutch we have have in ours ..love to know why the difference tho
Jezz_s13
Mmm, that clip is from the Nissan FSM that someone in Australia scanned IIRC. It's the S13 200sx manual for the CA18DET.
How odd. :confused:
cortina-mk1
the manual we use is for australian spec nissan exa (N13) none of which were turbo here
and as i said the clutch is smaller again
arr well beats me :)
