Clutch Damper help!
YuNg1's_240sx
Car: 1995 Black 240sx SE
hey guys i need some help ASAP! zer...-helpArashp.s. please do not flame, I am frustrated enough from the stripping!!
TheCandyManS13
Car: 1991 Nissan 240SX
Flare Hardline tools, depending on the quality, will expand depending on how tight the bolt is. I used a Monkey Wrench to get mine out and then retightened it with some sealant tape and a Flare hardline wrench.
Once you get the Clutch dampener out just bleed the system like normal.
As for the bleeding, google "How to bleed clutch system" it will explain it pretty well.
You're going to unscrew the bleeder valve, press down the clutch pedal, and while keeping the clutch pedal pressed down, you tighten it, that way you don't suck the air back into the clutch line. At that point, you'll loosen the valve and push the clutch pedal, and while keeping it pressed you tighten the valve. Rinse and repeat until the clutch is nice and firm.
YuNg1's_240sx
okay, now im not sure if the flare is 37* or 45*...does anyone know?
TheCandyManS13
if those asteriks are degrees... the angle doesn't matter. 37 would be easier to work with though. Mine are 37 degrees.
If they're not degrees, I really don't know what you're asking.
YuNg1's_240sx
yeah they are degrees. I am going to get the flare tool from advance auto and give it a go. It will be tough with the little room under the car though...
Cone Junky
Car: S13 fastback
BMW e46 328i
Signatures like yours should be banned. How the hell am I supposed to concentrate on butts, I mean cars, with that jiggling in my face?
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
No s*** right, every time I see that I'm like oooooh, ok.
TheCandyManS13
Awww, you likez it I know i do.
YuNg1's_240sx
So I went under my car again today, and realized that this attachment to the cylinder is not returning all the way. The base of the attachment(at the top) on the transmission is not snug, it moves. Sometimes I have to manually pull out the attachment to get the pedal moving full motion againMy clutch pedal does not follow my foot all the way out (stops a good distance away from the point where it would be all the way out). What is at fault, the cylinder's piston, or the attachment? Now I have reason to believe that the retainer spring isn't on tight because I can move the withdrawal lever from the base just a bit. I think i've got this figured out.
Modified by YuNg1's_240sx at 9:21 PM 7/30/2009
Modified by YuNg1's_240sx at 9:22 PM 7/30/2009
