Ive searched and read up on some similar problems ppl have wrote on the forums but still want some opinions... I drive a 92 coupe, dohc 5-speed, and I just noticed tonight that theres a strange noise coming from the front of the car as i depress the clutch and go to put my car into gear. not a high pitch whining or popping noise, but a noise similar to...the power antenna going up or down....that "type" of sound. And its not exactly hard to put it in gear, but i notice a noise that i didnt notice before today. It doesnt happen with the car in neutral, only when i press the clutch in, and try to put it into any gear. It just started snowing today but i doubt that has anything to do with it? Is it TO bearing issue? Im gonna go out and drive it up the road to see if i can diagnose it any further tonight, but please throw out some opinions...other than search. Thanks alot
one other thing i was having clutch issues before but it was the slave cylinder. i replaced that and the master, and everything has been fine since...
If this is a TO bearing problem, how bad is this gonna be?
