kps13silvia »
https://forums.nicoclub.com/kps13silvia-u168173.html
Wed Sep 22, 2010 3:35 pm
So i changed my clutch in my 300zx, now when lifting the trans back up into position it hits the top of the tunnel, and the input shaft is past the pressure plate and touches the protruding lip of the clutch disc right by the splines because it still has a little ways to go up but it cant because the trans is already as high as it can go, ive been messing around with it for a couple of days with no luck, Fyi it was a f1 racing xlite chromoly flywheel and an exedy stage 2 clutch that i replaced the factory setup with. any input is great appreciated, Thanks.
