Clutch Change?
PhaneSoul
Car: 89 Nissan 240SX SE Black 5spd Wrecked
95 Nissan 240SX SE Green 5spd s14.5 yay!
Do yu have to replace the gasket when you do a clutch change?
180fan
Car: 89 fastback
what gasket? Usually I change the pilot bushing, throw out bearing, clutch, pressure plate, and have the flywheel resurfaced.
navysnail
while you have the flywheel off it may not be a bad idea to go ahead and do the rear main seal while you have the transmission and flywheel off
s13sr20chris
that would not hurt. there is a gasket for the shifter but just use rtv or something.
PhaneSoul
allright, and do i have to use anything to seal up the transmission when i put it back so nothing leaks? and whats the best way to get the transmission plug open??
s13sr20chris
only around the shifter. be carefull with the plug and use good hand tools. no impacts allowed.
