Clutch Break In Period
otterman
I just got a Exedy Stage 2 3-puck clutch. The instructions said to allow 750 miles for it to break in. Will I be able to notice a difference after the clutch has broke in or are there any common things that'll happen while a clutch is getting broke in? I've only got 10 miles on the clutch right now and it's running good I just want to know if there should be anything to expect while it breaks in so that I dont freak out and think somethings wrong when in fact it's normal. (I love run on sentences)
Emc-Icon
Car: 1990 240sx (in the middle of ka24det swap)
for all i know.. jsut grandma the hell out of it for the first 500 miles...and then beat on it a coupla times to completely settle it..
rsmithdrift
Car: 1993 240sx fastback se.
I have a OEM replacement (previous owner put it in 50miles before I bought it) and the pedal hieght came up and it got more smooth (less abrupt) grab feel too it after 400 miles.
I had to readjust the pedal a couple of times to compensate. 4000 miles later and it still act the same as it did after it settled at 400 miles.
JesusLikesKFC
Car: 91 240sx, geo prizm
clutch breakins are always hard and tempting. i waited about 500 hard as hell miles and nothing changed i have a spec clutch rated to 450tq. btw good luck with resisting... u know what im talking about.
Emc-Icon
so.. um.. explain to me.. what exactly would happen if i gave in to the temptation?...
Florida240sx
hehehe I got abuilt engien and new clutch. I want to drive hard, and want to do it now.....going to be difficult to resist with that turbo....
Masterkillalw
Car: 89 240sx HB
Really depends on the clutch. I put a stage 1 exedy in my S13 and it said go for 750 miles before going hard on it.
ricebike
2002 Quest
2005 Altima
Emc-Icon wrote:so.. um.. explain to me.. what exactly would happen if i gave in to the temptation?...
u might "glaze" the lining, just like you do w/ brake pads if you don't "bed da linings" properly...
that's my common-cents thinking
Florida240sx
You suppose to break in brakes as well? I guess going drag racing that night wasn't such a good idea....
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Florida240sx wrote:You suppose to break in brakes as well? I guess going drag racing that night wasn't such a good idea....
Yes you are, but it doesn't take as long as breaking-in the clutch:http://www.zeckhausen.com/bedding_in_brakes.htm
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
LoL. Don't u just hate that! during the break in period u want to shift it at different RPM ranges (softly). After the 500-750mile mark is past. Have fun CHirp'N!! LoL.
BlueTyGator
Car: 1992 240SX SE
I'm breaking in my new stage 3/ 4 paddle ceramic right now. Truth is I couldn't resist. I've gotten on it a couple times now and I'm only up to about 200 miles...
My mechanic told me that as long as I dont absolutly lay into it (double clutching and what not) that I would be fine. Is he right or should I start keeping it under 3500.
WI_S14_Goldie
Keep it under 3500. When u start getting up to 350-400miles i heard u should start shifting higher, like at 4000 etc. (Note: ur doing this softly) give ur clutch a variety of different RPMs...
BlueTyGator
Car: 1992 240SX SE
so what kind of damage am I looking at for dogging it a little early on???
Glazing, less grab??
574-240sx
Car: Nissans, Toyotas, Subaru
I have had new pucked clutches slip before its basically like overheating a broke in pucked clutch. It will take away from the life of the clutch and its max capabilites and proling the break in time. By the way I'm hard on clutches and transmissions.
BlueTyGator
Car: 1992 240SX SE
Well there sorta made to be abused,,, who am I to argue with the transmission Gods
