clutch booster in s14
Dnight07
Car: s14
I've heard of some people in nz that have done clutch boosters in s13 with rb swaps they need it to do so because of the tripple plate clutch , any info on this i'll be needing something like that since my s14 didn't come with one, and it'll be a b%^$ to use a tripple plate on my daily driver.. with out a clutch booster
is there a way to use the z32 or 300 one on a 240sx?
if anyone has any info please let me know..
Indolent
Car: coupe
i don't think any s13/s14's came with 'clutch' boosters, at least not that i know of
not sure about z32/300zx buton my gtr33 front clip it came with one, so maybe you could modify one on your car, but the gtr pedal is longer, but you need to use the master cylinder associated with it, the bolt pattern's smaller and the master cylinder is different as well, i believe the bolts that go through the firewall may be opposite of the s13/s14 bolt pattern, i forgot and i'm lazy to check until i upgrade/modify my car to make it work
Dnight07
Car: s14
would you consider selling the set up?
kjlindgr
I have a triple plate HKS in my car and no booster is needed. Just take your skirt off and push it.
BlAcK95sE
Car: black 95 240sx se
kjlindgr wrote:I have a triple plate HKS in my car and no booster is needed. Just take your skirt off and push it.
Dnight07
Car: s14
thanks for the info... is it your daily driver?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Triple plate of death
