SloS13 »
https://forums.nicoclub.com/slos13-u1021.html
Sun Jan 04, 2004 10:58 am
This sounds rediculous, but it worked great for me:
1. remove dampener2. Open slave bleed enough to get a little drippage3. Very slowly pour in brake fluid (About 1/2qt)4. Close slave bleeder
Might not work for everyone, but just using gravity to remove the air worked perfectly for me somehow. Clutch is a Spec Stage III, so Id definitly know if it was grabbing when it wasnt supposed to. Much better pedal feeel after removing dampener.
Note: Clean area around dapener bolts as good as you can, and let the dampener bolts marinate in some PB Blaster before trying to remove them
