heres pictures to help you along but its pretty straigh foward:
http://darkrume.com/index.php?...=4158
heres a step by step:Credit to
http://www.nostreetracing.org/...?a=11:
www.nostreetracing.org wrote:What You Will Need
* Jack & Jack stands * 14mm Open-end Wrench * 10mm Flared Open-end Wrench (note this is a MUST) * 12mm Socket or Wrench * Something to let fluid drip into (old pan or bowl) * Recommend some old/shop rags or towels
I will start with the bypassing of the clutch dampener box, as it is easier to do this mod before installing the stainless line since you will already have all the hardlines undone and ready to connect to the stainless line.
A Few Notes & Reasons for this mod
1. About the Dampener * The clutch dampener box is supposed to cushion the clutch pedal. * It works like a surge tank with a loop-back system to relieve clutch pedal pressure. * It is there to piss you off while bleeding the clutch. 2. The "Why?" * The purpose of this mod is to take the play out of the hydraulic clutch on the S13. * Removing the dampener block makes it much easier to bleed the clutch along with a more "sportier" feel. It also lets the clutch engage at a higher point (in most cases). * When you install a heavy aftermarket clutch, sometimes the hydraulic system struggles to handle the added pressure when you depress the clutch pedal. This is evident when the clutch has been fully bled but still doesn't want to disengage all the way. * For some this mod is done purely because they like the stiff, live feeling of the pedal afterwards. You have a closer connection with what your clutch is doing. 3. Precautions * I must warn you, before doing this, that you could seriously screw your clutch system up if you do this wrong. * If you don't have access to replacement hard lines, you may want to reconsider bending yours until you do. * As always when playing with brake fluid, be sure not to drink it or get it in your eyes... and keep it off your paint! (It eats paint really quickly.) Brake fluid washes out with water.
Installation (*Note* Some pics and info credited to ZERO YŌN)
Start by jacking up the front of the car, and supporting each side with jack stands.
This is what the factory system looks like:
A closer look:
Using the 10mm Flared wrench, disconnect all of the hard lines.
After removal of the short line, take the long line and carefully bend it by hand. Be sure not kink it (You can use a tube bending tool if you have one, but its not necessary. You should be fine as long as you're careful when bending by hand). You will be turning it around and pointing it into the slave cylinder connection directly.
Now go ahead and remove the loop back and blocks. (12mm bolts holding them to the chassis)
At this point you have two options:
1. If you have a Stainless line, skip the next step, and continue through the rest of the the article for instructions on connecting the line. 2. If you do not have a stainless line: Screw the bended hard line into the factory rubber tubing:
Fill the master cylinder with brake fluid and bleed the clutch line (bleed valve on the slave cylinder). You will find bleeding this system takes only a few minutes, instead of all day like the stock system. Be sure to clean up the mess, and you're done!
Now for the installation of the stainless line. This is really simple compared to removing the dampener box.
1. About stainless lines * Most stainless lines are the same. * The K2RD line is a copy of the Earl's, while the Earl's is a copy of the Nismo... they all do the same thing. * You can spend $100 on Nismo lines or $20 on SPL lines, they're the same thing. It's up to you if you want to spend the extra money. 2. Factory vs. Stainless * The stock rubber line can swell letting the clutch not engage fully, so a stainless line fixes that permenantly. * Sometimes the factory line is so old, it won't hold the pressure, and the car will creep forward even if you have your foot on the clutch pedal. It may also happen after some spirited driving, due to heat. * A stainless line will usually give a stiffer clutch pedal feel.
Installation
On the end of the factory line which connects to the hard line, remove the clip that holds it into place.
Pull the line out of the metal lip that was holding it.Using the 14mm wrench, disconnect the factory line from the slave cylinder.
Now screw in your stainless line in its place. Put the other end back into the lip.
Replace the clip that held the factory rubber line.
Now screw the hardline into the stainless line.This is what the finished product should look like:
Finish up by filling the master cylinder with brake fluid and bleeding the clutch line. Clean up the mess and you're done. You should notice a stiffer clutch pedal feel than before.
