Clutch Bleeding Problems
S14DrifterSC
Car: 96 240sx w/SR20DET
Whats up everyone. I have been having problems with air getting in my clutch lines and I'm having to bleed it about once every two weeks. I was wondering if anyone has had similar problems or would know what was causing the air to get into the lines. Any info would be highly appreciated.
tazjig
Car: 1990 240sx (SR20)
most likly your clutch master cylinder, i had a simalar problem but it was with my brakes and it was my brake master cylinder.
Luke
Do you have Nissan OEM Master and Slave cylinders?
Are you losing any hydraulic fluid?
Does the clear fluid you use turn black shortly after bleeding? (seals going bad in master cylinder)
Have you bypassed the clutch damper and ran the line straight to the slave cylinder?
S14DrifterSC
Thanks for the advice although I just replaced the master cylinder and the slave cylinder probaly three months ago. By the way thats a sweet *** car man.
