clutch bleeding problems. 240sx
erehemantresni
Ok the slave and master were replaced 20k miles ago. so both are good. somehow the bleeder screw came loose and i lost pressure in clutch hydraulic system.ive been messing with this thing for 45 minutes now. is there anyway to bleed the clutch faster/easier? also what the hell is the block that is between the master and slave? thanks!@
180fan
Car: 89 fastback
Make it easier by pulling that big square thing with the loop off (damper loops). With the hardline going to the rubber line directly, it'll make the bleed much easier.
Get a pump, put it on the nipple, fill up the hose with some fluid, and pump till you get some good pressure and open the bleeder. Tighten it back down after you pull the fluid, and repeat till no bubbles in there if you want it to be a one man job. Otherwise have your friend pump the pedal a couple times, and then you open the bleeder to let the fluid pass through, and repeat till the lines are clear of bubbles.
erehemantresni
where did you get the fittings to make an adapter?
