clutch bleeding issues
fishtail
Car: S13 240sx
I'm having trouble bleeding my clutch in my s14. I've replaced the slave cylinder and clutch line so far.
this is what it's doing: I'll fill the master cylinder and pump the pedal a few time and turn the bleeder screw 1/4 turn, fluid comes out so I know that the lines have fluid in them but the clutch feel stays the same and the slave cylinder only moves a small amount. also the pedal remains stuck to the floor while the bleeder screw is closed.
Can anyone help me out on this one?
mister2nr
You have air trapped in the system somewhere more than likely. Sometimes bleeding a clutch system can be a pain, but you will need to have you and a buddy do this just keep pumping the pedal and cracking the bleeder screw until you get a good pedal. If you have not been doing this already.
