rb25drag wrote:Yup thats the only way unless you machine bleed it.
Try,
1. Having another person under the car ready to open and close the valve2. Build up pressure by stepping on the clutch a few times until it is stiff3. Now, Push very hard on the clutch, (your buddy now opens the valve and when the clutch pedal reaches the ground tell him "Close it!".
You have to keep doing this and Keep Refilling the Resevoir~~~~~
NOTE: If this is A brand NEW Clutch Cylinder:::: YOU Are RECOMMENDED to bleed it Manually with your HANDS on a table VISE.
