180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Nov 28, 2006 12:52 am
buying an assembly will be:
bracketarmrubber cover for the pedalreturn spring3 plastic pieces that the return spring attaches tonut and bolt for the pivotpossibly the clevis pin where the pedal attaches to the master cylinderusually the switch that will let you turn on the carlittle green or white colored plastic piece that keeps the pedal from going clang on the bracket.
dealership:those parts are all separate. the bracket alone is about 30-40 bucks, the actual pedal is about 50 and the prices go on.
