clutch and peeling out problem...
the420man
i was trying to take off and peel out on a homie the other day. and getting off of first gear it red lined and wouldnt let me go into any other gear. the cluth just got stuck and it stay down on the floor and never came up till the rmp went back down. was this because of hte VCD? any help would be good
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
That sucks man, I don't know much about the vdc on the 6mt, but I don't like it in general... I have a 5AT and I tried a 6mt 3.5 L maxima that would roast at 30ish mph... on a test drive.
I think you should check it out though, Good luck, I'm drunk, more intelligent responses to follow.
infinititech1
its designed to do that
telcoman
I think you should check it out though, Good luck, I'm drunk, more intelligent responses to follow. [/QUOTE]
I'm glad you are at your computer and not driving
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
telcoman wrote:
I think you should check it out though, Good luck, I'm drunk, more intelligent responses to follow. ...(end quote tag removed by rn for clarity.)
At first telcoman, I thought... then I realized you just screwed up the quote tags. That post would really have been out of character for you...
I just thought I'd quote this before you edit it, that way, the guys can come along and you a little...
the420man
guess it does sucks. hopefully i didnt do anything bad to the transmission. i think your suppose to turn off the VDC before you can start peeling out and drift somewhat huh?? but thanks anyways
joe603
Car: 2014 Durango R/T
infinititech1 wrote:its designed to do that
I disagree. This is a common problem in some G's. There is a service bulletin on the clutch slave cylinder. Take it to the dealer and have them fix it!! Mine did it too....before replacing.
Oh, and the VDC will not affect your clutch. If you try and do a burn-out with the system engaged, it will simply cut power and apply brakes to the spinning wheels.
infinititech1
i guess thats just what i heard...never had that complain come into the dealer
joe603
Drew, where in GA are you?
G_whizz
Car: 2010 G37 Coupe Sport
the420man wrote:i was trying to take off and peel out on a homie the other day. and getting off of first gear it red lined and wouldnt let me go into any other gear. the cluth just got stuck and it stay down on the floor and never came up till the rmp went back down. was this because of hte VCD? any help would be good
This is too funny!
FYI... this is the EXACT same question I had when I first bought my 05 G and decided to Google the answer... BAM... that's how I found NICO!!
Follow Joes advice!!
infinititech1
valdosta
joe603 wrote:Drew, where in GA are you?
the420man
well thanks for the tip i guess on my next service ill ask them about it and see if they can do anything for me.
grantman240z
Car: '03 G35 Coupe 6MT
If you try to spin the tires with VDC on...you are going to find that you won't go very far. VDC will cut your throttle back and squeeze the brakes on the loose tires until they stop. With VDC off, you should have no problem destroying some rubber if you really want too...
joe603
infinititech1 wrote:valdosta
Wow...damn! Thats northern Florida
Gonna go to NOPI in September??
telcoman
rn79870
Yes I did screw up the quote. I may be an old farht but it took me awhile before I figured out how to edit a quote and reply to it without the whole long quote.
It took me months before I learned how to post a photo.Then again some of the younger members don't know everything either.
Telcoman
