clutch and flywheel install problems
doctorj240
Car: Black s14 w/ redtop
I decided to swap out my clutch for a spec stage 2 clutch and fidanza 11 lb flywheel last night. Unfortunately after everything was assembled it wouldn't start. We push started it and it ran beautifully but the damn thing won't start from a dead stop. Our guess is one of the sensors isn't connected or broken. If anyone has had this problem please help me out. I need to break it in so I can go race this weekend.
240SXer
Car: 1995 240sx SE (2jz powered)
How was the flywheel?
doctorj240
It's great. The engine revs faster and launches are better because of less inertia. I think that makes sense doesn't it? With both the clutch and flywheel I probably picked up .2 sec on the quarter mile which is pretty respectable. Overall I'm very happy.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Does the engine turn over and not catch or it does nothing? If it does nothing you probably forgot to hook the starter back up, since push starting the transmission turns the flywheel to crank the engine. Thats my two cents.
doctorj240
It ended up being that the clutch switch was being pushed down or something. All we had to do was adjust the clutch pedal position and it fired right up.
JNM240
Cool. :)
240SXer
How is the performance with the flywheel? Should I get one? does it make it hard to drive? does it get worse gas milage?
David.
doctorj240
Get it when you burn out your stock clutch
