Clutch alignment tool?? HELP!!!
solow240
Car: 91 240sx s13
Ok guys heres the problem i bought another s13 with a blown up sr20 in it the motor is at the machine shop right now, and i should have it back anyday now, the problem is i had to remove the clutch when i disassembled everything and i do now have an alignment tool for the sr20, does anyone know where i could get one or what other veichles like maybe at sr20 sentra, that may use the same alignment tool, Thanks in advance!!
Ilvemynissan
Car: 240sx s13
An alignment tool? I've done a few clutches and never used and 'alignment' tool. I'm pretty sure you dont have to use it.
lostconcepts
Car: S13
I got one from the parts store last time I did my clutch.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Ilvemynissan wrote: An alignment tool? I've done a few clutches and never used and 'alignment' tool. I'm pretty sure you dont have to use it.
You've been lucky then. Without the tool, the clutch disc won't go on the input shaft and sit in the pilot bushing very easily.
So long as you can find a 24 spline alignment tool, you should be gravy. KAs, SRs, and Maximas all use the same spline count input shaft.
If worse comes to worse, use the trans to do it. You can set the clutch and pressure plate on the trans input shaft, and then get the pressure place bolted on with a few bolts. Pull the trans off and finish tightening the bolts.
Ilvemynissan
Car: 240sx s13
I guess I should look into this then.
