jtbenfie »
https://forums.nicoclub.com/jtbenfie-u148892.html
Mon Jan 11, 2010 4:01 pm
PEZi is prettymuch right. Hydraulic clutches generally have no adjustment and are self adjusting.
This holds true for the 720's there is a small adjustment to correct pedal hieght by means of a threaded rod where the clutch pedal connects to the master cylinder, but it is not intended to correct engagement/disengagement issues.
What problems are you having?Most common issue on our trucks is the slave cylinder on the side of the trans leaking and causing the clutch to not disengage. pull back the boot and see if any fluid is trapped behind there. a very small amount is acceptable because of the age of our trucks, but it should be minimal. Also look at the clutch master cylinder and dampener for leaks, but usually its the slave.
Also, its possible the fork is worn or the throwout/release bearing is gone, but those usually get noisy to let you know there is a problem.
If all else fails and nothing is obvious, just bleed the clutch hydraulics, it uses dot 3 brake fluid, bleeder is on the slave.
