Clutch adjustment
Kryptonite
Car: corvette
I have 1989 240 clutch has no room before it engages can someone enlighten me on this is their an adjustment bolt or screw
Axel Grungy
Car: 2001 G20 5spd
stick your head up under your dash and look at the back of the pedal. bascially you will need to rotate the rod via unscrewing a nut and removing a pin IIRC. just look at it, youll figure it out.
